Einleitung
Zu Schritt 1 der AnleitungThis is a teardown of a dual USB port bracket with LED activity lights for a desktop computer. These brackets, which mount on any open expansion card slot on a computer chassis, add two USB ports to the back of a computer using a connection to a 9-pin USB header on a motherboard. This one came out of a desktop with an MSI motherboard.
Was du brauchst
Werkzeuge
This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
These connectors plug into the USB headers on the motherboard.
In diesem Schritt verwendetes Werkzeug:Phillips #1 Screwdriver$5.49
Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
The two USB 2.0 ports.
The four LED lights, which light up depending on the activity of the USB ports.
Raise the three connectors from the case and it's out!
The connectors highlighted in red lead to the wires that connect the bracket to the motherboard.
The two USB ports.
The LED activity lights.
2 Kommentare
Why does it need its owe usb header just for the LED's.
That "usb header" is especially for MSI motherboard diag. status (mobo K8T Neo2 FIR 6802E, D-Bracket 2)
