Einleitung
The Toniebox is a popular audio player for children over the age of three, with easy-to-understand touch controls and small figurines (Tonies) with integrated NFC that work sort of like cassettes or CDs (remember those?). Why stop at an unboxing when we've got a perfectly good teardown table?
Toniebox, prepare to meet your unmaker.
Want to stay plugged in to the latest teardown and repair news? Visit our Facebook, take a look at our Instagram, and follow us on Twitter, to not miss a bit.
Was du brauchst
The Toniebox is designed as an audiobook player for kids (age three and up), and packs the following features:
Motion control, via slapping the side or tilting the box
Small figurines (Tonies) with built in NFC chip
Soft shockproof shell
Internal storage for up to 400 hours of audio data
7 hours battery capacity
Magnets in the top of the Toniebox, and in the sockets of the Tonies, to keep them stuck together while you tilt and turn the box
Because we're doing this teardown in Germany, we'll forgo the usual metric and imperial measuring shenanigans and simply give you a banana for scale.
Each side of this cube measures 3/4 of a banana. (4.7 inches or 12 cm according to the manufacturer, who evidently did not have a banana handy.)
Placing the banana onto the NFC sensor also doesn't play anything.
The cover on the bottom is as stubborn as a pickle jar. But hey, we have seen far worse opening procedures! Besides, the rest looks pretty easy.
A single Phillips screw holds the innards in the foam housing. Just the way we like it.
It is a snapfit connection. Try pushing against the bottom with your palm while turning counterclockwise.
It’s very hardto open it. There are 2 small slots for the snappers.
2 possible ways to get access to these:
1.a) You can try to remove the sticker (with the toniebox logo) at the bottom
OR
1b) Make two little holes with a screwdriver in the sticker . Imagine the radius from the (charging port) to the “B” of the word “Boxine” “Designed by <B>oxine in [..]“ Make a hole under the “B”and one mirrored at the center along the radius.
2.)After that you can use a small screwdriver to push the snappers back and turn the bottom part counterclockwise.
Actually we just created a guide on how to open the Toniebox. Take a look here: Toniebox öffnen
Press and turn worked easily for me, anticlockwise.
Now for the "unboxing".
The main components lift right out the top of the box. Easy peasy.
Surrounding it is this black cage, which is also easy to take out and seems to serve mainly for crush protection.
The squeezable foam bumper comes out last. According to the manufacturer, it's made from sustainable fabrics.
The battery pack and motherboard are secured with just two standard Phillips screws.
As printed on the back, the battery pack consists of three NiMH batteries with a capacity of 2,000 mAh.
The manufacturer states this is a nickel-metal hydride (NiMH) battery pack—chosen because it's a safer technology than lithium-ion, and has almost no memory effect.
We'll have a look at that motherboard just as soon as these stubborn little cables are unplugged. Let's see what all the noise is about! Onboard we find:
Texas Instruments C3200R1M2 microcontroller serving as CPU and WLAN Receiver
ISSI IS25LQ032 flash memory
A Texas Instruments DAC3100 TI 7BI ANVS G4 Audio Controller
Battery loading IC
A TRF7962A RFID Reader to read the NFC chips from the Tonies
NXP MMA8451 accelerometer for fast forward and rewind functions.
And a Sandisk Edge 8 GB MicroSD card formatted as Fat32
Ist die Speicherkarte durch eine größere Tauschbar zB. 16GB Fat32?
Hat das schon mal jemand getestet??
Schau mal hier nach ;)
Kann man das Motherboard irgendwo erwerben? Ich habe einen Wackelkontakt, vermutlich am Netzstecker.. Mit einem anderen Akku lief die Box wieder nur kann ich den ja nicht jedes Mal tauschen, geschweige denn aufladen.
Wenn es mit einem anderen Akku lief, ist dann vlt der alte Akku durch? Dafür gibt es Ersatz. Wo man ein neues Motherboard herbekommt, weiß ich leider nicht. Die Lötstellen vom Akkuanschluss auf dem Motherboard zu kontrollieren kann auch nicht schaden. Die kann man evtl auch selber noch mal selber wieder korrekt anlöten.
Hallo, hat jemandem zufaellig die SD Daten? meine SD Karte ist hin Danke
Any ideas on the exact audio jack part being used? I’m needing to replace it on my board.
Look in the comments further down :)
Toniebox Teardown -
And now for the Toniebox's vocal
chordscords! -
Speaker specs: 4 Ω and 3 W. 'Nuff said. We weren't exactly expecting high fidelity audiophile hardware, after all.
Moin,
meinen sie es ist möglich den Lautsprecher durch einen Neuen zu ersetzen, der eine bessere Klangqualität hat?
Vlt einen Tipp parat, bzw welche Größe/Maße hat der LS?
Beste Grüße
Jan
Hallo, weiss jemand die genaue Bezeichnung des JST Steckers vom Lautsprecherkabel? Ist es ein JST XH 3 Pin?
Just four more Phillips screws, and we can remove the cap.
Inside the cap we find a second PCB, this one responsible for the NFC connection.
Except for another socket to connect with the motherboard and another crossed out trashcan (WEEE-Symbol), there's nothing to see here.
The antenna has a plug for 6 PINS, were several do have a connection. Visible on the antenna I see only one circuit.Why did the use 6 PINS? Are there some loops on a different PCB layer?
Hi,
unsere Box erkennt keine Tonies mehr, laut Aussage von Boxine, ist dann die NFC Antenne kaputt und die kann nicht ersetzt werden.
Wenn ich mir das hier angucke, scheint es ja als ob eine neue Antenne einfach die Platine wäre… Heißt das, dass ich brauche die Platine neu brauche?
Ich kann mir nicht vorstellen, dass die Antenne defekt ist. Möglicherweise sitzt sie nicht mehr korrekt im Steckkontakt
Next we inspect the volume control buttons, located (rather appropriately) in the ears of the Toniebox.
Removing the outer layer of the ears, we find two small buttons.
Because the buttons connect to the motherboard via a JST plug, we don't need to cut a wire. Lucky us.
Gibt es wohl eine Möglichkeit diese Taster in den Ohren zu ersetzen? Oder die gesamten Ohren zu tauschen?
Was für ein JST Stecker wird da verwendet? Eine Typenbezeichnung wäre hilfreich. Danke
Hi there, my teething toddler has bitten through the plastic ears/volume control on our Tonie box. Can these be replaced?
Looking for specs on the buttons, or a replacement assembly. My Toddler bit through one.
Hi, there is a german guide here on ifixit : Toniebox Defektes Ohr reparieren
Bonus teardown: We perform minor surgery on the lion figurine and find, as expected, an NFC chip in his stomach.
Um welchen Chip handelt es sich genau?
Auf dem Chip war leider keine Bezeichung zu sehen, die beim Identifizieren helfen könnte.
War es euch moeglich den Chip auszulesen?
Bisher haben wir noch keine Methode gefunden den Chip auszulesen.
You can read them now to create a backup: https://media.ccc.de/v/36c3-108-hacking-...
That's all, folks! We completely tore down our Toniebox, cut open the lion, and spread everything over the table. Here is our result:
All the screws are standard Phillips screws and no adhesive was used.
The box is easy to disassemble and reassemble, without damaging it or leaving any marks.
Battery pack and flash memory are also pretty common and easy to change.
The cap on the bottom is held in place by plastic clips, which could break if you open the box repeatedly.
Some of the plugs sit in their sockets pretty tight and might be hard to unplug without damaging the sockets.
The headphone jack is soldered to the motherboard.
Super! Danke für den tollen Beitrag! Hat jemand eine Idee wie man eine defekte Kopfhörerbuchse reparieren könnte?
Das haben sich schon andere gefragt :) hier findest du einen Hinweis eines anderen users: Toniebox Teardown
Huhu,
ich würde gern nur die Ohren erneuern. Was muss dafür alles raus aus der Box? Also ich muss ja nicht alles auseinander nehmen, um neue Ohren einzubauen oder?
Thank you so much for this break down, it gave me the confidence to fix one of our 3 units we have. 20 min + £3 equals £60 savings and a happy kids and happy dad.
what was the fault out of interest - we had one die under warranty, and i found an area on the board which ad clearly had a fault occur, some innards were no longer inside one of the capacitors and a few skid marks in the local area of the board from overheating it looked like.
Hat schon jemand die kopfhörerbuchse gewechselt meine kleine tochter hat die komplett beschädigt
Thanks so much! With this knowledge I'll look at integrating the small Bluetooth transmitter we bought inside the unit instead of stuck awkwardly onto the outside where small fingers can fiddle with it.
Is there anyway to replace the charging port/ circuit board please? My boy flooded the underneath with water and it is showing signs of previously being wet and the socket is rusted.
100%
Hier starten ›
84 Kommentare
Hallo.
Das finde ich mal Klasse.
Da muss ich unseren gar nicht mehr aufschrauben!
Und das ganze so detailiert.
Danke.
Großartig! Was verbirgt sich in der Ladestation? Ist da nur ein Halter für den Stecker oder auch eine Lade Elektronik?
In der Ladestation befindet sich lediglich der Stecker vom Netzteil – keine weitere Elektronik.
Vielen Dank für die sehr schöne und ausführliche Anleitung. Mir ist aufgefallen, dass ich die NFC-Chips der Tonies nicht mit meinem Handy (Samsung S6) auslesen kann. Weiß da jemand was genaueres drüber? Auch mit einem RFID Reader konnte ich den Chips keine Informationen entlocken.
Finden wir ebenfalls interessant und haben aber auch noch keine Möglichkeit gefunden, die NFCs auszulesen. Möchtest du hierzu vielleicht eine Frage im Forum stellen, da finden sich eventuell weitere Reaktionen und Beiträge. Danke
Ist ein ISO15693 Chip (vermute einen icode Slix-L)
Kann mit einem Multi-ISO reader ausgelesen werden.
Die tonies sind standardmäßig gesperrt und werden von der Toniebox entsperrt. Versuche, den Tonie kurz auf die Box zu klopfen und dann auszulesen.
Vielen Dank für das Teardown. Meint ihr ich kann die Speicherkarte durch eine größere ersetzen? Sinn wäre ja lediglich mehr „Tonies abzuspeichern“ oder?
Danke
Freut uns, dass dir der Teardown gefallen hat. Das mit der größeren Speicherkarte wäre ein interessanter Ansatz. Könnte möglich sein. Schau dir auf jeden Fall die Formatierung der Karte genau an und was für Dateien darauf sind. Eventuell eine 1:1 Kopie auf die größere ziehen und dann versuchen. Würde mich sehr freuen, wenn du damit dann einen Guide (als Technique) erstellst. Viel Erfolg
Wie weit ist die lösung
matthias -
Gibt es genaue Bilder der Platine möchte unsere nicht unnötig aufmachen
Intresse:
-Bluetooth
-Speicherkarte
-Anderen NFC bzw eigene erkkennen lassen
matthias -
Hallo,
gibt es da noch einen weiteren Trick, wie die Box unten zu öffnen geht? Ich drücke und drehe (gegen den Uhrzeigersinn), hab schon die Befürchtung die Box bald zu zermalmen.
Problem gelöst. Es geht wirklich nur um Kraft. Ich hab meinen Mann um Hilfe gebeten :D
Genau, einfach mal herzhaft zupacken ;) Die Box ist sehr robust. Und nach dem ersten Öffnen geht es auch ein wenig einfacher.
Hallo,
Ich hatte auch Probleme die Box aufzubekommen. Am leichtesten geht es wenn du die Box normal auf einen glatten Untergrund stellst, dich von oben raufstützt und dann die Box drehst. Der Gummiring im Sockel halt dann die Bodenplatte fest und die Box geht recht leicht auf.
Großartig - vielen Dank für den Teardown!
Ein paar Fragen hab ich noch:
Sind in den Tonies nicht noch Magnete? D.h. auf der Seite der Toniebox sollten ebenfalls noch Magnete sein, oder? Und gibt es nicht so etwas wie einen Hall-Effekt Sensor der da noch verbaut ist?
Super Arbeit jedenfalls!
Stimmt, im Sockel der Figuren ist ein Magnet, an der Toniebox eine kleine Metallplatte. Einen Hall-Effekt-Sensor haben wir nicht gefunden.
Thanks for the tear down.
What is in the memory card ? Just the downloaded audio files ?
Since there seems to be no other memory on the board maybe there is a custom Linux installation in there as well ?
Tolle Anleitung! Bei uns ist die Platine/Motherboard durchgebrannt….bekommt man irgendwo ein neues?
LG Manu
Vielen Dank für den Teardown der Toniebox. Die Toniebox meines Enkels hatte nur mehr auf der Ladestation funktioniert. Also zerlegt, festgestellt das sie schon mal mit Wasser Kontakt hatte. Die Korrosion auf der Platine mit einem Glasfaserpinsel entfernt, einen neuen Akku eingebaut, und alles Funktioniert wieder :-)
Könnte ich den Chip eines “kreativ tonies” ohne Probleme in eine Kunststoff \ Resin figur einbringen und ihn weiterhin verwenden?? Oder müsste ich dabei etwas beachten??
Ja der Chip muss immer senkrecht stehen, waagerecht funkt der nicht
Rodaron -
Hiho. Eure Meinung, meine Frau liebt die toniebox und ich bin am überlegen ob man die Box tunen könnte… Also besseren Akku und bessere Lautsprecher mit vllt etwas mehr bass^^ wäre sowas für ein elektro leihen umsetzbar? Ist es überhaupt umsetzbar ein weiteren Lautsprecher einzusetzen? Mfg
Beim “tunen” des Akkus wäre ich etwas vorsichtig. Der Lautsprecher kann bestimmt gegen einen anderen getauscht werden, solange er von Form und Größe in die Halterung und den Rahmen passt. Vielleicht noch auf die Werte achten (Widerstand und Leistung nicht überdimensionieren) und den Stecker umlöten. Viel Erfolg – falls es klappt, könnt ihr ja einen guide daraus machen ;)
Hallo! Hat das geklappt? Bin mit dem Lautsprecher und resultierendem Klang sehr unzufrieden.
Peter S. -
Hab hier grad was gepostet mit paar Bilder von ausgelötetem Chip/TAG. Es ist von einem Kreativ-Tonie Astronaut.
https://www.mikrocontroller.net/topic/43...
Die Chipbezeichnung ist SYK128 (SYK 128)
Zu Versuchszwecken habe ich auch schon größere Antenne/Spule dran gelötet, wird dann auch von der TonieBox erkannt, von Smartphone oder TRF7970A EVM aber nicht.
Hallo,
bei der toniebox kann man einen Track weiter und zurück geheb, indem man ihr einen “Klaps” auf die Seiten gibt. Womit registriert die Box das?
Hallo Noni, das registriert die Toniebox mittels eines Beschleunigungssensors. Dieser erkennt, von welcher Seite die Box “geklappst” wird bzw. auf welche Seite die Box geneigt wird (zum schnellen Vor- und Zurückspulen).
Hallo Gianga, wir haben noch keine Quelle gefunden. Am Besten mal die Buchse auslöten und zum Elektrofachhandel gehen oder online recherchieren. Sollte eine 3,5 mm Klinke zum Einlöten sein. Hat unten noch zwei kleine Kunststoffnasen, zur Positionierung auf der Platine.
Hallo Tonie Freunde,
kann mir jemand sagen wo der Beschleunigungssensor verbaut ist? (denke irgend ein Teil auf der Hauptplatine, aber welches genau?)
Hallo Markus,
Ich habe mir die Platine nochmals genauer angeschaut und habe vermutlich den sensor gefunden. Schaue doch einfach im aktualisierten Schritt 6 das zweite Bild an. Der vorletzte Bullet hat auch einen Link zum Bauteil. Ich hoffe, das hilft etwas weiter.
Vielen Dank,
hättest du einen Link wo man das Teil kaufen kann (obwohl es löttechnisch nicht einfach ist will ich es mal versuchen…….)
Leider nein. Aber evtl findest du was, wenn du im Netz nach MMA8451 suchst. Ist deiner kaputt? Viel Erfolg mit der Reparatur. (Du kannst glaub auch auf deine eigene Frage kommentieren, damit alles in einem Thread bleibt ;) )
Ja, ist leider kaputt! Bei der Suche nach MMA8451 finde ich leider nur Sensoren in anderer Bauform. Trotzdem vielen Dank für deine Hilfe.
Markus -
Es gibt ein Adafruit Triple-Axis Accelerometer Shield mit dem Bauteil drauf (sieht zumindest so aus und heißt so). Zur Not von dort ablöten?
Unsere Toniebox lädt nicht zuverlässig weil der Stift des Netzteils nicht weit genug in die Buchse ragt. Nur wenn man die Toniebox mit viel Kraft in den Pin presst bekommt die Buchse Kontakt und lädt. Wenn ich den weißen Deckel weglasse, kann ich Sie zuverlässig laden aber ich würde ungern dauerhaft auf den Deckel verzichten. Hat jemand eine Idee wie ich das reparieren kann und die Toniebox wieder Kontakt bekommt mit Deckel. Den Fehler hat die Box von Anfang an aber leider habe ich den Kaufbeleg nicht mehr und ohne weigert sich der Händler die Box umzutauschen.
Switchcraft 35RASMT3BHNTRX?
Pete -
Hallo Pete, ja es ist Switchcraft 35RASMT3BHNTRX, hat jemad eine Ahnung, wo ich das Teil einzeln herbekomme, bei Digi Key soll man 18€ Versand bezahlen, für einen Warenwert von ca 4,50€ .
Gruss
Hat jemand schon einen Händler gefunden wo man keine 18euro Versand für der/die/das Switchcraft 35RASMT3BHNTRX bezahlen muss????
Hier gibts das passende Ersatzteil: https://www.ebay.de/itm/185467695638?mkc...
Weiß jemand wie die Schalter in den Ohren heißen? Also die Bezeichnung. Unser Sohn hat einen kaputt gebissen
Besten Dank
Unsere toniebox wird nicht mehr lauter wenn ich auf das Ohr drücke . Was kann ich tun.
Hallo Angelina, vermutlich ist der Schalter in diesem Ohr defekt. Leider haben wir dafür bisher noch keine einfache Lösung. Es ist ein einfacher Druckschalter (siehe Schritt 9), den man eventuell von der winzigen Platine ablöten und selber einen neuen hinlöten kann.
Ich finde es ist eine ziemliche Sauerei, dass alles an einen Online-Dienst gekoppelt ist, anstatt die Inhalte wirklich in den Figuren zu speichern. Nichts gehört einem heute mehr. Völlige Abhängigkeit von einem Server des Anbieters.
Hallo Tatjana, nachdem man eine Figur auf die Toniebox stellt, wird (so weit ich weiß) der Inhalt erst herunter geladen und dann auf die Speicherkarte geschrieben, damit man es auch mobil ohne Internet verwenden kann.
Vielleicht interessiert dich dann dieser Diskussionsfaden von usern, die sich Gedanken machen, wie man die Daten der Speicherkarte der Toniebox sichern kann:
Hallo,
super Anleitung.
Aber wo kann ich die Ersatzteile bestellen.
Unser Kleiner hat ein Ohr abgebissen
Gruß
Liegt die Musik auf dem NFC-Chip, oder auf der SS-Karte und der Chip in der Figur „schaltet das nur frei „?
Hi corvintaurus, auf dem Chip liegt keine Musik. Diese ist auf der SD-Karte gespeichert. Der Chip enthält die Informationen für den Link/Download. Wenn du mehr über das Speichern der Musik wissen möchtest findest du hier einen guten Thread von zwei usern: https://de.ifixit.com/Antworten/Ansehen/...
Ich habe noch eine Frage, meine Toniebox lädt auf der Station, aber wenn ich sie runternehme, geht sie direkt aus und läuft nicht im Akkubetrieb, was kann das sein? Akku ist voll geladen und funktioniert an einer 2. Box tadellos.
Gruß
Hi. Weiß jemand was für ein Widerstand im Akku verbaut ist? Ich würde gerne eine alternativen Akkupack verbauen und bräuchte da mal die Daten zu dem verbauten Bauteil. Vielen Dank!
Klasse Arbeit…
Bei mir haben sich 2 Fragen aufgeworfen. Zum Einen, ob der verbaute Lade-IC kompatibel zu LiIon wäre, zum Anderen wüsste ich gern die größe des Lautsprechers…
Vielen Dank,
Meick
Super, danke. Jetzt weiß ich welcher Leser verbaut ist und welche Chips verwendet werden können.
Besten Gruß,
Phil
Bei uns ist ein Ohr defekt, da schauen nur noch 2 Kabel raus. Da fehlt was silbernes was klick macht bei der Lautstärkeregelung. Weiß jemand was ich da genau benötige oder was es kostet es reparieren zu lassen? Vielen Dank schonmal
Hallo vanessa.fernandez79, leider bieten wir keine Ersatzteile für die Toniebox Ohren an. Aber die von Toniebox (Boxine) haben einen Reparaturservice (siehe auch hier im Forum), frag doch mal bei denen nach.
Ist auf der Speicherkarte eine spezielle Firmware drauf, die man irgendwie wieder kopieren muss, wenn man eine andere SD-Karte einbauen möchte?
Guten Abend,
gibt es eine Anleitung oder einen Rat, wie die enthaltene SD-Karte am besten entnommen werden kann? Ich habe gesehen, dass sie mir einer Art weißem Klebstoff fixiert scheint und ich möchte ungerne bei der Entnahme irgendwas zerstören. Sieht auch ziemlich eng aus auf dem Board.
Deshalb auch noch eine Zusatzfrage: Existiert eine Anleitung, um den SD-Slot nach außen zu legen? Gelesen habe ich davon schon, doch eine bebilderte Anleitung mit notwendigen Teilen noch nicht gefunden.
Vielen Dank für jede Hilfe.
HalloZym Bo,
zur Toniebox gibt es bereits einige Fragen und auch Antworten in unserem Forum:
https://de.ifixit.com/Search?doctype=pos...
Vielleicht gibt es auch mittlerweile Infos um den SD-Karten-Slot nach außen zu legen. Es brauch vlt ein wenig Such-Geschick, um es in der Flut an Informationen zu finden. Das weiße “Zeugs” an der SD Karte kann man vorsichtig entfernen (abknibbeln), dann den Metallbügel öffnen um an die Karte zu kommen. Viel Erfolg
Hallo,
welche Maße hat das Herzstück und der innere Plastikkäfig?
Möchte gerne in das Gehäuse andere Elektronik einbauen…
Wo finde ich denn die Buttons zum laut und leiser machen also das ganze Kabel plus die Ohren.
Kann ich das Kabel für die Ohren Taster direkt auf den Taster löten wenn ich die kleine Platte PCB (?) nicht mehr habe ??
Hallo,
danke für die tolle Anleitung!
Leider ist bei unserer Toniebox das Bauteil T342 einfach von der Platine abgefallen. Kann mir jemand sagen, um welches Bauteil es sich handelt, damit wir ein neues bestellen und auflöten können?
Vielen Dank :-)
Das scheint ein Transistor zu sein (einer der vielen im Haufen an Transistoren oben links auf der Platine mit drei Lötbeinchen). Davon gibt es wohl mehrere, falls also nicht mehr vorhanden, Nummer eines benachbarten Moduls (zB T343) notieren und nachbestellen.
Was ist l320 oben von sd slot beim genaueren hinsehen hat der audio controller analog input auf pin 13 und 14 und ein vol mic detect auf 11 ?
Hallo, bei unsere Toniebox ist anscheinend SD karte defekt. hat jemandem zufaellig die SD Daten gespeichert? Danke
Hallo, so ein Bluetooth adapter für kabellos Kopfhörer (iclever kids) würde klasse! Leider kein gefunden das funktioniert! Alle kann man mit dem Kopfhörer verbinden aber 10 sek. Im Toniebox gesteckt dann geht die ton wider aus die Lautsprecher vom Toniebox! Wenn eine eine Bluetooth adapter gefunden habe das geht bitte sagen.
Hallo!
Hat jemand eine Idee, was “kaputt” ist, wenn die Box keine Tonies mehr erkennt? Also gar keine.
Hab die Box komplett auseinandergenommen, Platine und alle Komponenten sehen gut aus, keine blinden Lötstellen zu erkennen. Aber das “blöde” Ding will die Tonies partout nicht erkennen.
Ich wäre über Ideen echt dankbar!
Hy findet man die tonie ID auch noch anderweitig? Wir haben die Zugangsdaten vergessen und die Kids den Aufkleber abgemacht.
Gibt's da noch weitere Möglichkeiten die irgendwie rauszubekommen?
Wär echt genial wenn ihr uns weiterhelfen könntet!
Die ID kann mittelt der MAC-Adresse der Toniebox und einer Anfrage beim Tonie Support ermittelt werden.
Die genaue Anleitung dazu liefert der folgende Tonie Support Artikel: https://support.tonies.com/hc/de/article...
Martin -
is there a guide on how to replace the wifi Antenna, My son's toniebox is having an issue connecting to wifi unless you are right next to the router
Ich habe ein kleines Projekt überlegt und wollte fragen ob ihr denkt, dass es funktionieren kann: habe mir eine refurbished TB bestellt und werde versuche eine reisebox in deutlich flacher daraus zu bauen - sprich die Platine horizontal einbauen, Lautsprecher gegen Bluetooth Sender ersetzen oder weiteren Klinke Stecker (zwei Kinder). Zwei potentielle Probleme sehe ich: passt die Platine auch horizontal von den Maßen zu den Außenmaßen? Was macht das Accelerometer wenn die Ausgangsposition flach ist?
Sehr gute Anleitung!
Weiss zufällig jemand die Bezeichnung für die Ladebuchse? Unsere hat einen Wackelkontakt und ich hätte diese mal vorsorglich getauscht. Finde nur leider nicht das exakte Bauteil, bzw bin mir bei manchen Angeboten nicht sicher ob Stiftdicke passt.
Ist die vom Asus X53 baugleich?
Ich denke, es ist folgende Buchse (5,5mm x 2,1mm):
DC-044b 5521
Die vom Asus hat einen 2,5mm Stift, also eher nicht.
Xeno -
Übermorgen haben wir die erste Tooniebox im Repaircafé. Vielen Dank für Deine Anleitung!
Not really. The storage is the Micro SD. The NFC is only giving some kind of authorization I guess to download the file.
StuFF mc - Antwort
You’re right. We have corrected it. Thanks for the input :)
Tobias Isakeit -
