Zum Hauptinhalt wechseln
Dell Inspiron 17R-N7110 Keyboard Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
Dell Inspiron 17R-N7110 Keyboard Replacement: Schritt 0, Bild 1 von 3 Dell Inspiron 17R-N7110 Keyboard Replacement: Schritt 0, Bild 2 von 3 Dell Inspiron 17R-N7110 Keyboard Replacement: Schritt 0, Bild 3 von 3
  • Do not pull the keyboard away from the laptop. The keyboard is connected to the motherboard by a cable. Pulling the keyboard may cause damage to the keyboard and/or motherboard.
  • Metal spudgers and similar prying tools can damage internal components like the motherboard. It is ideal to use a regular black nylon spudger or a plastic opening tool, but for this device the metal jimmy was the only tool to work.
  • Flip over and open your device. Gently wedge the metal Jimmy into the rightmost hole at a 45-degree angle. Make sure that the Jimmy is between the silver metal portion of the keyboard and the silver plastic edge around the keyboard.
  • Tilt the metal jimmy away from you to pry up the edge of the keyboard.
  • Repeat the previous actions on each of the other three holes to release the keyboard.
Hier Übersetzung einfügen
