Schritt 1 übersetzen
Schritt 1
Surface Preparation
Begin by removing all the old adhesive, glass, and any other debris from all adhesion surfaces.
After removing most of the adhesive, scrape with the tip of a spudger to get small bits of adhesive out of tight spaces.
[title] Surface Preparation | |
[* black] Begin by removing all the old adhesive, glass, and any other debris from all adhesion surfaces. | |
- | [* icon_note] You can pull the adhesive off with tweezers or your fingers, [https://d3nevzfk7ii3be.cloudfront.net/igi/omScJRSckUhIpVcT.huge|roll it up on the tip of a spudger|new_window=true] with a roll-and-pull motion, or scrape it off with the flat end of a spudger. |
+ | [* icon_note] You can pull the adhesive off with [product|IF145-020|tweezers] or your fingers, [https://d3nevzfk7ii3be.cloudfront.net/igi/omScJRSckUhIpVcT.huge|roll it up on the tip of a spudger|new_window=true] with a roll-and-pull motion, or scrape it off with the flat end of a spudger. |
[* black] After removing most of the adhesive, scrape with the tip of a spudger to get small bits of adhesive out of tight spaces. | |
[* icon_caution] When working around a battery, be extremely careful not to accidentally puncture or bend the battery. |
