Zum Hauptinhalt wechseln
iPad 7 LCD Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 5
iPad 7 LCD Replacement, Disconnect the battery: Schritt 0, Bild 1 von 3 iPad 7 LCD Replacement, Disconnect the battery: Schritt 0, Bild 2 von 3 iPad 7 LCD Replacement, Disconnect the battery: Schritt 0, Bild 3 von 3
  • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
  • Ensure that the iFixit logo on the battery blocker is facing up.
  • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
  • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
  • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
  • Leave the battery blocker in place as you work.
Hier Übersetzung einfügen
