Zum Hauptinhalt wechseln
Dell Inspiron E1505 GPU Replacement
Englisch
Deutsch
Schritt 4
Dell Inspiron E1505 GPU Replacement, Keyboard and display: Schritt 0, Bild 1 von 3 Dell Inspiron E1505 GPU Replacement, Keyboard and display: Schritt 0, Bild 2 von 3 Dell Inspiron E1505 GPU Replacement, Keyboard and display: Schritt 0, Bild 3 von 3
  • Remove the two screws and slide the keyboard toward the display.
  • There is a delicate ribbon cable attached to the bottom of the keyboard. Be careful when removing it.
  • Rotate the latch up toward the trackpad, then carefully remove the ribbon cable.
  • Remove the antenna connectors on the wifi card by pulling up at the part where the cable meets the connector.
  • Unscrew the grounding cable on the display cable. Disconnect the display cable by pulling up on the tab.
  • Remove the last two screws holding the display in. Rotate the display to an upright 90-degree position. Gently pull up to remove the display.
Hier Übersetzung einfügen
