Zum Hauptinhalt wechseln
iPhone 16 Pro Max Display tauschen
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 9
iPhone 16 Pro Max Screen Installation: Schritt 0, Bild 1 von 3 iPhone 16 Pro Max Screen Installation: Schritt 0, Bild 2 von 3 iPhone 16 Pro Max Screen Installation: Schritt 0, Bild 3 von 3
  • Use a spudger or your fingers to lift the pull tab connected to the large front liner—the pull tab is often in a corner of the liner.
  • Use the pull tab to peel off the large front liner from the adhesive.
  • At this point, you may still have liners covering the perimeter, which prevent the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
Fasse die kleine Ziehlasche in einer der oberen Ecken an und ziehe die große vordere Schutzfolie ab.
In manchen Ausführungen besteht diese Schutzfolie aus vier kleineren Teilen statt einem großen Stück.
-[* black] Grab the small pull tab (located at one of the corners) and peel off the large front liner from the adhesive.
-[* icon_note] On some versions, this liner may consist of up to four smaller pieces rather than a large single piece.
+[* black] Use a spudger or your fingers to lift the pull tab connected to the large front liner—the pull tab is often in a corner of the liner.
+[* black] Use the pull tab to peel off the large front liner from the adhesive.
+[* icon_note] At this point, you may still have [link|https://guide-images.cdn.ifixit.com/igi/5PVXOAEQsFPoENVM.full|liners covering the perimeter|new_window=true], which prevent the adhesive from accidentally sticking to anything while you're reassembling your iPhone. ***Don't remove these small release liners just yet.***
