Schritt 1 übersetzen
The pad removal process in this guide is performed with the caliper off of the vehicle. The installation process is documented with it on the vehicle. Both procedures can be done with the caliper on the vehicle. The calipers were off of this car for cleaning, since the soft rubber hoses were being replaced too.
You'll need to remove your wheels to perform this work.
The first step is to remove the brake pad wear sensors. First, disconnect them from the sensor harness bolted to the caliper.
Then use a needle nose plier to remove the sensors from the old pads. The wires may break as they did on this set, but you can still grab the sensor body to remove it.
These sensors cannot be re-used. They should be replaced with the pads.
