Zum Hauptinhalt wechseln
Sony Xperia Z Battery Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 7 übersetzen
Schritt 7
Sony Xperia Z Battery Replacement: Schritt 0, Bild 1 von 3 Sony Xperia Z Battery Replacement: Schritt 0, Bild 2 von 3 Sony Xperia Z Battery Replacement: Schritt 0, Bild 3 von 3
  • Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
  • Flex cables run vertically down the phone underneath the battery and can be damaged easily. Make sure to only place the spudger in the indicated area.
  • Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
Hier Übersetzung einfügen
