Zum Hauptinhalt wechseln
Fujifilm FinePix A350 Speaker Replacement
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
Fujifilm FinePix A350 Speaker Replacement: Schritt 0, Bild 1 von 3 Fujifilm FinePix A350 Speaker Replacement: Schritt 0, Bild 2 von 3 Fujifilm FinePix A350 Speaker Replacement: Schritt 0, Bild 3 von 3
  • Slide the speaker pad away from the back half of the case and out of its holster.
  • After the speaker pad has been removed, the two halves of the case will be connected solely by a ribbon cable leading to the screen. The speaker wires will remain attached to the motherboard.
  • To completely remove the speaker, use a soldering iron to desolder the red and black wires connecting the speaker to the motherboard. Note the black wire goes to the terminal closest to the outside of the camera.
  • If you lack experience in soldering, or need a refresher, refer to the iFixit soldering guide.
  • Desoldering the speaker is not a prerequisite for subsequent guides.
Hier Übersetzung einfügen
