Zum Hauptinhalt wechseln
iPod Touch 6th Generation Display Assembly Replacement
Englisch
Koreanisch
Schritt 4
iPod Touch 6th Generation Display Assembly Replacement, Opening the iPod: Schritt 0, Bild 1 von 2 iPod Touch 6th Generation Display Assembly Replacement, Opening the iPod: Schritt 0, Bild 2 von 2
Opening the iPod
  • Place a suction cup just above the home button, towards the lower section of the glass.
  • Press it firmly to ensure the cup has a strong seal.
  • Hold iPod firmly on a hard surface
  • To prevent you from breaking the ribbon cables connected to the LCD, Place your thumb and index finger over the lower corners of the display to stop the display from opening too far.
  • Start to Lift the suction cup, and start to firmly pull constantly until the adhesive breaks, and the display comes up from the rear case.
  • When lifting the screen apart if adhesive is still sticking to the display you may get a razor blade to cut the adhesive.
  • Be careful not to lift more than about an inch—a fragile plastic frame still connects the display assembly to the rear case.
Hier Übersetzung einfügen
