Zum Hauptinhalt wechseln
Dell Inspiron 14z N114z Memory/RAM Replacement
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
Dell Inspiron 14z N114z  Memory/RAM Replacement: Schritt 0, Bild 1 von 3 Dell Inspiron 14z N114z  Memory/RAM Replacement: Schritt 0, Bild 2 von 3 Dell Inspiron 14z N114z  Memory/RAM Replacement: Schritt 0, Bild 3 von 3
  • Unscrew one 6.75mm screw on the bottom of the access panel using a PH0 bit.
  • Pry up on the bottom edge of the access panel to remove.
  • Locate RAM in the upper left portion of the access panel. Using both thumbs, push out on the small locking arms, located on each side of the RAM. If done correctly, RAM will pop up to an accessible angle.
  • Carefully pull RAM out of the slot.
Hier Übersetzung einfügen
