Zum Hauptinhalt wechseln
iPad 5 Teardown
Englisch
Deutsch
Schritt 11 übersetzen
Schritt 11
iPad 5 Teardown, Final Thoughts: Schritt 0, Bild 1 von 1
Final Thoughts
  • The 5th-Generation iPad earns a 2 out of 10 on our repairability scale (10 is the easiest to repair):
  • The LCD is easy to remove once the front panel is separated from the iPad.
  • The battery is not soldered to the logic board. We'll give it that.
  • Just like in previous iPads, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass during a repair.
  • Gobs of adhesive hold everything in place. As with its Air 1 predecessor, this ranks among the most difficult battery removal procedures we've seen in an iPad.
  • The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
  • You can't access the front panel's connector until you remove the LCD.
Hier Übersetzung einfügen
