Zum Hauptinhalt wechseln
Dell Latitude E6540 Hard Drive Replacement
Englisch
Koreanisch
Schritt 2
Dell Latitude E6540 Hard Drive Replacement, Remove the drive clip: Schritt 0, Bild 1 von 3 Dell Latitude E6540 Hard Drive Replacement, Remove the drive clip: Schritt 0, Bild 2 von 3 Dell Latitude E6540 Hard Drive Replacement, Remove the drive clip: Schritt 0, Bild 3 von 3
  • EET owners: Your kit has this bit. No purchase needed.
  • This step is not required if you are moving the drive to an identical Dell computer.
  • To remove the drive clip, remove the Phillips #0 screw holding the hard drive to the clip.
  • Once the screw is removed, remove the drive starting from the side with the screw.
  • Remove the drive from the right side by removing the drive from the alignment pin.
Hier Übersetzung einfügen
