Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 1 übersetzen
Schritt 1
Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
Push the tool into the hole until you see the card pop out.
- | [* black] Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. |
+ | [* icon_note] Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off. |
+ | [* black] Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle. |
[* black] Push the tool into the hole until you see the card pop out. |
