Zum Hauptinhalt wechseln
Huawei Honor 8 Rear Glass & Frame Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 4
Huawei Honor 8 Rear Glass & Frame Replacement: Schritt 0, Bild 1 von 1
  • Keep the tiny screws on a magnetic pad or a designated area so they will not be lost. There are eighteen screws in total.
  • Using a Phillips PH00 screwdriver, remove the eight silver Phillips 3.5 mm screws circled in red.
  • Using a Phillips PH00 screwdriver, remove the six black Phillips 4.0 mm screws circled in orange.
  • Using a Phillips PH00 screwdriver, remove the single silver 3.0 mm Phillips screw circled in yellow.
  • Using the Phillips PH00 screwdriver tip, gently scratch away the white stickers outlined in green circles to expose hidden screws.
  • Using a Phillips PH00 screwdriver, remove the two black Phillips 4.0 mm screws circled in green.
Hier Übersetzung einfügen
