Zum Hauptinhalt wechseln
2015 Nissan Pathfinder Rear Windshield Wiper Replacement
Was du brauchst
  1. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement, Rear Windshield Wiper: Schritt 1, Bild 1 von 2 2015 Nissan Pathfinder Rear Windshield Wiper Replacement, Rear Windshield Wiper: Schritt 1, Bild 2 von 2
    • Gently life the wiper up and away from the windshield in an upright position.
  2. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 2, Bild 1 von 2 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 2, Bild 2 von 2
    • Using your finger and thumb, lift the wiper blade upward from the base.
    • The wiper should be sticking out and away from the windshield.
  3. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 3, Bild 1 von 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 3, Bild 2 von 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 3, Bild 3 von 3
    • Locate the pivot block at the end of the wiper arm that connects to the blade.
    • Pull the blade away with adequate force to remove the blade completely.
  4. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 4, Bild 1 von 1
    • Acquire the replacement blade and remove the rubber yellow protector.
  5. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 5, Bild 1 von 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 5, Bild 2 von 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 5, Bild 3 von 3
    • Locate the thin notch in the center of the replacement blade.
    • Locate the corresponding rounded port on the wiper arm.
    • Insert the notch into the arm and push together with mild force to attach the wiper blade to the arm.
    • When attaching the wiper blade to the arm, a clicking sound should be heard to ensure it is correctly assembled.
  6. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 6, Bild 1 von 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 6, Bild 2 von 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: Schritt 6, Bild 3 von 3
    • Gently fold the blade in and lay the wiper blade and arm back down on the windshield.
Ziellinie
Katie
133 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 33
Insgesamt: 467
