Zum Hauptinhalt wechseln
2017 Honda Civic Sport Brake Light Bulb Replacement
Theo Chisom
Theo Chisom und 2 weitere Mitwirkende
Zuletzt aktualisiert am May 8, 2023
10 - 30 Minuten
Leicht
With enough use, any light bulb will burn out and need replacing, and the brake light on your 2017 Honda Civic Sport is no different. The average life span for the light bulbs are two thousand hours, but varies dependent on the usage of the car. This guide demonstrates how to replace a brake light bulb when it burns out.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: Schritt 1, Bild 1 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: Schritt 1, Bild 2 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: Schritt 1, Bild 3 von 3
    • Turn your vehicle off before beginning.
    • Open your trunk.
    • Use a Phillips #2 screwdriver to remove the two screws securing the shield.
  2. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 2, Bild 1 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 2, Bild 2 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 2, Bild 3 von 3
    • To remove the brake light housing, start from the top of the frame and pull the shield outwards.
  3. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 3, Bild 1 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 3, Bild 2 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 3, Bild 3 von 3
    • Twist the brake light socket counterclockwise and pull it directly out, with care not to damage the wires.
    • The brake light has a gray plug.
  4. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 4, Bild 1 von 2 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 4, Bild 2 von 2
    • Grip light bulb and slide it directly out of its socket.
  5. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 5, Bild 1 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 5, Bild 2 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 5, Bild 3 von 3
    • Install a new bulb by pressing it into the socket.
    • You'll hear a "click" when it's properly inserted.
  6. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 6, Bild 1 von 2 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 6, Bild 2 von 2
    • Place the socket back in its housing and twist it clockwise.
  7. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 7, Bild 1 von 2 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 7, Bild 2 von 2
    • Align the brake light shield with the two sockets and firmly press the brake light inward.
    • You'll hear a "pop" when the shield is secured.
Abschluss
Enjoy your functional brake light!
3 weitere Personen haben diese Anleitung absolviert.
Theo Chisom
198 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 19
Letzte 7 Tage: 111
Letzte 30 Tage: 320
Insgesamt: 5,473
