Zum Hauptinhalt wechseln
ASUS PadFone X Rear Facing Camera Replacement
nestor
nestor und 7 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
15 - 30 Minuten
Leicht
Aus eins mach mehr
Bessere Einleitung
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: Schritt 1, Bild 1 von 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: Schritt 1, Bild 2 von 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: Schritt 2, Bild 1 von 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: Schritt 2, Bild 2 von 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: Schritt 2, Bild 3 von 3
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: Schritt 3, Bild 1 von 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: Schritt 3, Bild 2 von 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: Schritt 4, Bild 1 von 1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: Schritt 6, Bild 1 von 1
    • Once the camera has been pulled out, replace the old camera with a new camera.
Abschluss
nestor
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 8-4, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 546
