Zum Hauptinhalt wechseln
Acer Chromebook C710-2833 Wifi Card Replacement
Nicholas Latorre
Nicholas Latorre und 4 weitere Mitwirkende
Zuletzt aktualisiert am March 7, 2024
5 - 7 Minuten
Leicht
In this replacement guide, you will remove and install a wireless (wifi) card.
  1. Acer Chromebook C710-2833 Wifi Card Replacement, Wifi Card: Schritt 1, Bild 1 von 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 2, Bild 2 von 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 4, Bild 1 von 1
    • Locate the 3 mm Phillips #00 screw on the wireless card port.
    • Unscrew the screw and place it aside for now.
  5. Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 5, Bild 1 von 3 Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 5, Bild 2 von 3 Acer Chromebook C710-2833 Wifi Card Replacement: Schritt 5, Bild 3 von 3
    • Safely remove the wireless card by pulling it out of the bottom of the port.
    • Lastly, disconnect the two white and black wire connectors attached to the wireless card.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S1-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Replaced the original wifi card, how do you get Chrome OS to recognize, or find and download driver for Intel AC 7260 wifi card?
Thanks.
When Ze - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 791
