Zum Hauptinhalt wechseln
Acer Chromebook C720-2827 LED PCB Replacement
Was du brauchst
    1. Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 2 Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: Schritt 1, Bild 2 von 2
      • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Acer Chromebook C720-2827 LED PCB Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C720-2827 LED PCB Replacement: Schritt 2, Bild 2 von 2
      • Pry the back panel open with the plastic opening tool.
      Frag FixBot
    1. Acer Chromebook C720-2827 LED PCB Replacement, Battery: Schritt 3, Bild 1 von 1
      • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
      Frag FixBot
    2. Acer Chromebook C720-2827 LED PCB Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C720-2827 LED PCB Replacement: Schritt 4, Bild 2 von 2
      • Carefully pull out the battery wire connected to the battery port.
      Frag FixBot
    3. Acer Chromebook C720-2827 LED PCB Replacement: Schritt 5, Bild 1 von 1
      • Slowly lift the battery to remove it from the Chromebook.
      Frag FixBot
    1. Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: Schritt 6, Bild 1 von 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: Schritt 6, Bild 2 von 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: Schritt 6, Bild 3 von 3
      • Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
      • Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
      • The LED PCB is still tethered to the daughterboard via a ribbon cable so be sure not to yank it out or it could cause damage to the cable or its connectors.
      Frag FixBot
    2. Acer Chromebook C720-2827 LED PCB Replacement: Schritt 7, Bild 1 von 3 Acer Chromebook C720-2827 LED PCB Replacement: Schritt 7, Bild 2 von 3 Acer Chromebook C720-2827 LED PCB Replacement: Schritt 7, Bild 3 von 3
      • Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
      • Pull the ribbon cable out with your fingers.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 581
