Akai MPK25 Face Plate Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to properly remove the face plate from the chassis without damaging any of the components on the inside.
Was du brauchst
Werkzeuge
Using needle nose pliers, remove the washers from the four corner selector knobs.
Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
Carefully flip the device to the front making sure you secure the face plate and the chassis together.
Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
Eine weitere Person hat diese Anleitung absolviert.
