Anker 2.4G Wireless Mouse Scroll Wheel Replacement
Einleitung
Zu Schritt 1 der AnleitungIf your Anker 2.4 G Wireless Mouse scroll wheel is not working properly it may need to be cleaned or replaced. Over time dust can build-up in the mouse causing issues with scrolling, this can be resolved with a simple clean. If there is hardware damage, the scroll wheel may need to be replaced.
This guide will show you how to disassemble your Anker 2.4 G Wireless Mouse to repair the scroll wheel with little to no experience required.
For help with desoldering, see: Wie man Lötverbindungen herstellt und entlötet
Was du brauchst
Remove the stickers from the bottom of the mouse to have access to the screws, The stickers are shown in the picture by the red rectangles.
Use a Phillips #00 to remove the 4 screws shown by the red circles in the picture.
Using a plastic opening tool or spudger, on the center of the mouse, separate the upper and lower board.
Remove the wires from the white crimp headers, separating the upper and lower housing units of the mouse. Avoid pulling the wires too hard to prevent them from breaking.
Pull the scroll wheel put parallel to the board.
Replace/clean if needed.
If your mouse still does not work after this step, then continue to the next instruction.
Ein Kommentar
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
