Apple PowerBook G3 400 Hard Drive Replacement
Einleitung
Zu Schritt 1 der AnleitungTo replace the hard-drive, one must first remove the keyboard and RAM to be ready to remove the hard drive from the computer.
Was du brauchst
Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
Pull the keyboard ribbon vertically from the logic board to release connection.
Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
Lift the heat shield up and toward you.
Pull the PRAM battery cable vertically upward to disconnect it.
Remove the battery by pulling up and to the left.
Remove the two T8 Torx screws that attach the heat sink to the processor.
Remove the long silver Phillips #1 screw from the heat sink.
Lift the processor on the right side and pull directly up.
The RAM chips should be in the slots on the processor.
Locate the orange tab, which should be just left of the hard-drive.
You must disconnect this orange tab from the logic board to enable the next step.
It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
Grab the plastic strip shown here and gently remove, pulling up and left.
Pull left to avoid the hard drive catching the casing.
2 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
This is unnecessarily complicated and a danger to several connectors of your precious laptop: The hard drive bracket can be removed as soon as the RAM heat shield has been removed. No need to strain the CPU board connector.
When the hard drive bracket is out of the case, the cable can be disconnected safely from the hard drive.
The keyboard doesn't have to be disconnected either, it can just be put on the hand rest.
