Zum Hauptinhalt wechseln
Asus ROG FX60VM Hard Drive Replacement
Was du brauchst
  1. Asus ROG FX60VM Hard Drive Replacement, HDD: Schritt 1, Bild 1 von 2 Asus ROG FX60VM Hard Drive Replacement, HDD: Schritt 1, Bild 2 von 2
    • Before disassembling the laptop, turn the laptop off and make sure it's unplugged from the power supply.
  2. Asus ROG FX60VM Hard Drive Replacement: Schritt 2, Bild 1 von 3 Asus ROG FX60VM Hard Drive Replacement: Schritt 2, Bild 2 von 3 Asus ROG FX60VM Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop over so the back case is facing up.
    • Remove the ten 2.5 mm screws from the back case using a Phillips #0 screwdriver.
    • Use a plastic opening tool and picks to pry the back panel off of the device.
  3. Asus ROG FX60VM Hard Drive Replacement: Schritt 3, Bild 1 von 3 Asus ROG FX60VM Hard Drive Replacement: Schritt 3, Bild 2 von 3 Asus ROG FX60VM Hard Drive Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Halberd Spudger
    $2.99
    • Put the tip of Halberd spudger under the battery connector and lift it gently to disconnect it from the motherboard.
    • You may need to wiggle the spudger up and down in order to disconnect the battery connector.
  4. Asus ROG FX60VM Hard Drive Replacement: Schritt 4, Bild 1 von 2 Asus ROG FX60VM Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 3.0 mm screws from the HDD case using a Phillips #1 screwdriver.
  5. Asus ROG FX60VM Hard Drive Replacement: Schritt 5, Bild 1 von 3 Asus ROG FX60VM Hard Drive Replacement: Schritt 5, Bild 2 von 3 Asus ROG FX60VM Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Do not lift the HDD up, as you may damage the connector highlighted in red.
    • Hold the back of the HDD , and slide it out of the port to disconnect it from the motherboard.
  6. Asus ROG FX60VM Hard Drive Replacement: Schritt 6, Bild 1 von 3 Asus ROG FX60VM Hard Drive Replacement: Schritt 6, Bild 2 von 3 Asus ROG FX60VM Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Remove the two 3.0 mm screws on each side of the HDD mounting bracket using a Phillips #1 screwdriver.
    • Lift the HDD out of the mounting bracket, and install a new HDD or SSD to the mounting bracket.
Abschluss
After install a new HDD or SSD, for better performace, initialize the new disk.
Eine weitere Person hat diese Anleitung absolviert.
JingZhao Liang
163 Reputation
1 Anleitung geschrieben
York University, Team M-13, Allen Summer 2022 Mitglied von York University, Team M-13, Allen Summer 2022
YORK-ALLEN-SU22SMG13
1 Mitglied
1 Kommentar zur Anleitung
Thank you so much JingZhao Liang for the concise and to the point guide. It's easy to follow and I am very impressed that you mentioned how to dispose the e-waste properly in conclusion part.
Tayyaba Riasat - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 978
