Zum Hauptinhalt wechseln
Asus ROG G751JL-BSI7T28 Display Assembly Replacement
Was du brauchst
  1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 2, Bild 1 von 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 2, Bild 2 von 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 2, Bild 3 von 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: Schritt 3, Bild 1 von 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: Schritt 3, Bild 2 von 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 4, Bild 1 von 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 4, Bild 2 von 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 5, Bild 1 von 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 5, Bild 2 von 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 5, Bild 3 von 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 6, Bild 1 von 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 6, Bild 2 von 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 6, Bild 3 von 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 7, Bild 1 von 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: Schritt 7, Bild 2 von 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
Abschluss
Kristen Gismondi
92.209 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
19.481 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 385
