Asus ROG G752V Wireless Card Replacement
Einleitung
Zu Schritt 1 der AnleitungA wireless card is used to connect a computer to a wireless network (Wi-Fi).
If your Asus ROG G752V is giving a blue screen or the wireless card is damaged, this means that the wireless connection is not working and a repair is needed.
Before starting the guide below, it is important to disconnect the charger from the laptop and make sure that the laptop is completely shut off before starting.
Be sure to have all the specified tools that are listed below before starting the replacement process.
Now follow these steps below in order to fix the issue.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using a pair of tweezers, remove all 11 rubber plugs off of the back cover.
Using a Phillips #0 screwdriver, remove all twelve 5.2mm screws on the back of the laptop.
Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
Use the iFixit opening tool to pry apart the back panel from the main body of the laptop.
Using an ESD safe tool, detach all 3 ribbon cables. To do so, lift up the cable up and out.
Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
Using your hands, unlatch the wireless card by pulling it out toward the screen.
2 weitere Personen haben diese Anleitung absolviert.
