Zum Hauptinhalt wechseln
Asus ROG Strix GL702VS Motherboard Replacement
Conor H Allen
Conor H Allen und 6 weitere Mitwirkende
Zuletzt aktualisiert am August 16, 2022
20 Minuten - 1 Stunde
Mittel
Benötigt Bessere Bilder
This is a step-by-step walkthrough on how to remove the motherboard from an ASUS Republic of Gamers STRIX GL702VS laptop. If it has been determined that the motherboard is failing, consult this guide for removal and replacement. Common issues include boot failures such as CPU or GPU initialization failure on startup. Reference iFixit troubleshooting guide here to help determine the issue. The part number for a new motherboard will vary based upon your desired CPU, GPU and RAM.
Remember, computer components are fragile. Be careful with clips and wiring when disassembling and reassembling the computer. They can easily break or get pinched. It may also be helpful to take a picture of wiring routing and component placement before disassembly as a reference for reassembly. Note that there are multiple screw lengths in this application. Pay attention to their locations.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Asus ROG Strix GL702VS Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 3, Bild 1 von 2 Asus ROG Strix GL702VS Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: Schritt 5, Bild 1 von 3 Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: Schritt 5, Bild 2 von 3 Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: Schritt 5, Bild 3 von 3
    • Remove the four 4.8mm JIS #0 screws (two on each fan).
  6. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 6, Bild 1 von 3 Asus ROG Strix GL702VS Motherboard Replacement: Schritt 6, Bild 2 von 3 Asus ROG Strix GL702VS Motherboard Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the fan's connector on the motherboard using a pair of tweezers.
    • Be gentle, as the small clips and wires can be easily damaged.
  7. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 7, Bild 1 von 2 Asus ROG Strix GL702VS Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Gently lift each fan up and out of position.
  8. Asus ROG Strix GL702VS Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Disconnect the screen connector by lightly pulling the clip out.
    • The wires are delicate; disconnecting shouldn't take much force.
  9. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the seven 4mm JIS #0 screws from the motherboard.
    • One may be hidden, requiring disconnecting the screen connector.
  10. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 10, Bild 1 von 2 Asus ROG Strix GL702VS Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Unscrew the two 6.5mm JIS #0 screws located at the top corners of the motherboard.
  11. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Using the opening tool, lift up the flaps that secure the screen to the base.
  12. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Disconnect the Wi-Fi antenna by unplugging the black and white wires located behind the ethernet port.
    • For reassembly, note the corresponding triangles for each wire.
  13. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 13, Bild 1 von 3 Asus ROG Strix GL702VS Motherboard Replacement: Schritt 13, Bild 2 von 3 Asus ROG Strix GL702VS Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Use a spudger tool to lift the connector tabs on the motherboard and slide the four ribbons out.
  14. Asus ROG Strix GL702VS Motherboard Replacement: Schritt 14, Bild 1 von 2 Asus ROG Strix GL702VS Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Grasp the motherboard where the fans are located and lift up.
    • Do not force it. If you feel resistance, restart this guide to ensure you have removed all screws and connectors.
Abschluss
To reassemble the device, follow these instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
4 Kommentare
Any recommendation on WHERE to get a replacement mobo for this unit? Not having any luck in tracking one down.
help - Antwort
Try ebay -- that's where I got mine.. arrived in a few weeks from China.
turgut kalfaoglu - Antwort
What I wonder is that, when replacing the motherboard, should I remove all the aluminium tape that's at the bottom of the case? I suspect some of it has lifted and caused a short previously..
Yes I just replaced the motherboard. There are lots more tips that could have been added here but I used this page to remember where the screws are. Many thanks..
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,738
