Zum Hauptinhalt wechseln
Blackberry Curve 8320 Speaker Replacement
Christopher Aiello
Christopher Aiello und 5 weitere Mitwirkende
Zuletzt aktualisiert am January 28, 2014
15 Minuten
Mittel
This guide will show you how to:
  • Remove the battery
  • Remove the front panel
  • Replace the speaker
Was du brauchst
Werkzeuge
  1. Blackberry Curve 8320 Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 Blackberry Curve 8320 Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Speaker Replacement, Front Panel: Schritt 3, Bild 1 von 3 Blackberry Curve 8320 Speaker Replacement, Front Panel: Schritt 3, Bild 2 von 3 Blackberry Curve 8320 Speaker Replacement, Front Panel: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Speaker Replacement: Schritt 4, Bild 1 von 2 Blackberry Curve 8320 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Speaker Replacement: Schritt 5, Bild 1 von 2 Blackberry Curve 8320 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Blackberry Curve 8320 Speaker Replacement, Speaker: Schritt 8, Bild 1 von 3 Blackberry Curve 8320 Speaker Replacement, Speaker: Schritt 8, Bild 2 von 3 Blackberry Curve 8320 Speaker Replacement, Speaker: Schritt 8, Bild 3 von 3
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Blackberry Curve 8320 Speaker Replacement: Schritt 9, Bild 1 von 2 Blackberry Curve 8320 Speaker Replacement: Schritt 9, Bild 2 von 2
    • After the bottom two screws have been removed the side casings can be removed.
  10. Blackberry Curve 8320 Speaker Replacement: Schritt 10, Bild 1 von 3 Blackberry Curve 8320 Speaker Replacement: Schritt 10, Bild 2 von 3 Blackberry Curve 8320 Speaker Replacement: Schritt 10, Bild 3 von 3
    • Remove the back case.
    • The speaker is located on the back case.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 3-6, Regan Fall 2011 Mitglied von Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,026
