Zum Hauptinhalt wechseln
Dell Inspiron 13 7378 Display Assembly Replacement
Terrence15
Terrence15 und 2 weitere Mitwirkende
Zuletzt aktualisiert am August 14, 2022
15 - 30 Minuten
Leicht
Anleitung eines Community-Mitglieds
In this guide, we will be showing you how to remove and replace the Display Assembly.
Was du brauchst
Werkzeuge
  1. Dell Inspiron 13 7378 Display Assembly Replacement, Peeling off the Tape: Schritt 1, Bild 1 von 2 Dell Inspiron 13 7378 Display Assembly Replacement, Peeling off the Tape: Schritt 1, Bild 2 von 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Peel off the pieces of tape that secure the display cable and touch-screen board-cable to the system board.
  2. Dell Inspiron 13 7378 Display Assembly Replacement, Open the Latches: Schritt 2, Bild 1 von 1
    • Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
  3. Dell Inspiron 13 7378 Display Assembly Replacement, Open the Display: Schritt 3, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  4. Dell Inspiron 13 7378 Display Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Place the computer face down on a flat surface.
    • Remove the screws that secure the display assembly to the palm-rest assembly.
  5. Dell Inspiron 13 7378 Display Assembly Replacement, Lifting the Display Assembly: Schritt 5, Bild 1 von 1
    • Lift the display assembly off the palm-rest assembly.
  6. Dell Inspiron 13 7378 Display Assembly Replacement, Placing the Display Assembly: Schritt 6, Bild 1 von 1
    • Place the NEW display assembly face down on the palm-rest assembly.
  7. Dell Inspiron 13 7378 Display Assembly Replacement, Align the Screw Holes: Schritt 7, Bild 1 von 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  8. Dell Inspiron 13 7378 Display Assembly Replacement, Replace the Screws: Schritt 8, Bild 1 von 1
    • Replace the screws that secure the display assembly to the palm-rest assembly.
  9. Dell Inspiron 13 7378 Display Assembly Replacement, Close the Display: Schritt 9, Bild 1 von 1
    • Close the display and turn the computer over.
  10. Dell Inspiron 13 7378 Display Assembly Replacement, Securing the Cables: Schritt 10, Bild 1 von 1
    • Slide the display cable and the touch-screen board-cable into their respective connectors on the system board and close the latches to secure the cables.
  11. Dell Inspiron 13 7378 Display Assembly Replacement, Adhering the Tape: Schritt 11, Bild 1 von 1
    • Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
Abschluss
Terrence15
79.555 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
Ein Kommentar
Hi, I was wondering if there's any possibility of cross compatibility between i7378 and i7359 from dell? My computer is the i7359 but I haven't been able to find a reasonably priced replacement display. Thank you very much!
Ankita C - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 1,812
