Dell Inspiron 13 N3010 Hard Drive Replacement
Einleitung
Zu Schritt 1 der AnleitungIn this guide, we will show you how to remove and replace the Hard Drive.
Was du brauchst
Fix Kit
Dieses Kit enthält alle Ersatzteile und Werkzeuge, die für die Anleitung benötigt werden.
Ersatzteile
Werkzeuge
Mehr anzeigen …
Remove the screw that secures the hard-drive assembly to the system board.
Slide and disconnect the hard-drive assembly from the connector on the system board as indicated in the illustration.
Lift the hard-drive assembly off the system board.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Lift the hard-drive bracket away from the hard drive.
Replace the four screws that secure the hard-drive bracket to the hard drive.
Place the hard-drive assembly on the system board.
Slide and connect the hard-drive assembly to the system board connector.
Replace the screw that secures the hard-drive assembly to the system board.
Eine weitere Person hat diese Anleitung absolviert.
