Dell Inspiron 15 7560 Memory Modules Replacement
Einleitung
Zu Schritt 1 der AnleitungIn this guide, we will be showing you how to remove and replace the Memory Modules.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
2 weitere Personen haben diese Anleitung absolviert.
