Zum Hauptinhalt wechseln
Dell Inspiron 15-5567 Hard Drive Replacement
Saaed Chaudhry
Saaed Chaudhry und 2 weitere Mitwirkende
Zuletzt aktualisiert am February 3, 2022
30 - 40 Minuten
Mittel
Benötigt Bessere Bilder
Bessere Einleitung
Laptops can start to lose value to you when you run out of storage. This guide is an easy way to replace the hard drive for a Dell Inspiron 15-5567 laptop. When working with laptops it is important to make sure that there is no current running through the laptop and that is completely shut down before being opened up. The interior of a laptop is very delicate and therefore must be handled with great care to make sure nothing gets scratched inside that might impact the function of the laptop.
Was du brauchst
Fix Kit
Dieses Kit enthält alle Ersatzteile und Werkzeuge, die für die Anleitung benötigt werden.
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Dell Inspiron 15-5567 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove thirteen 8.5 mm screws from the bottom of the laptop.
    • Using the same screwdriver, remove the two 3.2 mm screws and slide the DVD drive out of the laptop.
  2. Dell Inspiron 15-5567 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 15-5567 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 15-5567 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the three 2.3 mm screws underneath the CD drive using the Phillips #0 screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 15-5567 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Disconnect cable covering the hard drive by prying up on the clamp holding the cable.
    • Disconnect the cable from the motherboard.
  4. Dell Inspiron 15-5567 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-5567 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the three 5.6 mm screws from the hard drive.
    • Remove the old hard drive from the laptop.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Saaed Chaudhry
478 Reputation
2 Anleitungen geschrieben
York University, Team S1-G8, Melo-Thaiss Summer 2021 Mitglied von York University, Team S1-G8, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G8
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 25
Letzte 30 Tage: 48
Insgesamt: 2,595
