Dell Inspiron 15-7567 Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungTaking out the battery is easy to replace when needed. It may need to be replaced if the battery dies quickly.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
Pinch the clips on the left and right side while pulling on the cord at the same time.
2 weitere Personen haben diese Anleitung absolviert.
