Zum Hauptinhalt wechseln
Dell Inspiron 1564 RAM Replacement
Tyson Duerr
Tyson Duerr und 8 weitere Mitwirkende
Zuletzt aktualisiert am April 24, 2018
Keine Schätzung
Mittel
Bessere Einleitung
The RAM on the Dell Inspiron 1564 laptop needs replacing over time. When there are source-demanding programs, the RAM is the first component to be maxed out which can tend to make your computer run slow. Use this guide to remove and replace the RAM.
Was du brauchst
Werkzeuge
  1. Dell Inspiron 1564 RAM Replacement, RAM: Schritt 1, Bild 1 von 2 Dell Inspiron 1564 RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Locate the battery latch on the bottom of the computer and slide it to the right.
    • While holding the battery latch, pull the battery away from the device.
  2. Dell Inspiron 1564 RAM Replacement: Schritt 2, Bild 1 von 1
    • With the Phillips #0 screwdriver, loosen the three screws from the cover behind the battery latch.
  3. Dell Inspiron 1564 RAM Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 1564 RAM Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 1564 RAM Replacement: Schritt 3, Bild 3 von 3
    • Locate the RAM on the bottom of the computer.
    • Remove the RAM by gently pulling back the small clips along the side of the RAM, and lifting the RAM upwards so the RAM is now angled.
    • Pull the RAM away from the device.
    • Repeat the actions above for the second stick of RAM.
    • When reinstalling the RAM, put it back in at an angle in the socket, and make sure the RAM is audiblely clicked into place.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 1,007
