Zum Hauptinhalt wechseln
Dell Inspiron 3552 Hard Drive  Replacement Part 1
Jordon Dozier
Jordon Dozier und 2 weitere Mitwirkende
Zuletzt aktualisiert am July 26, 2024
15 Minuten
Mittel
Grammatikfehler
Unklarer Text
Anleitung eines Community-Mitglieds
part 2: Dell Inspiron 3552 Hard drive Replacement part 2 - iFixit Repair Guide
Was du brauchst
Ersatzteile
  1. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the battery: Schritt 1, Bild 1 von 1
    • Close the display and turn the computer over
    • Slide the battery-release latch to the unlocked position
    • Lift the battery at an angle and remove the battery from the battery bay
  2. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing optical drive: Schritt 2, Bild 1 von 1
    • Remove the screw that secures the optical-drive assembly to the base cover.
    • Using a plastic scribe, push the optical-drive assembly out of the optical-drive bay.
    • Pull the optical-drive assembly out of the optical-drive bay.
  3. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: Schritt 3, Bild 1 von 2 Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing keyboard: Schritt 3, Bild 2 von 2
    • Turn on the computer over and open the display
    • Using a plastic scribe, gently release the tabs that secure the keyboard to the palm-rest assembly
    • Slide the keyboard up to release it from the slots on the palm-rest assembly.
    • Carefully turn the keyboard over and place it on the palm-rest assembly
  4. Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: Schritt 4, Bild 1 von 3 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: Schritt 4, Bild 2 von 3 Dell Inspiron 3552 Hard Drive  Replacement Part 1, Removing the base cover: Schritt 4, Bild 3 von 3
    • Open the display and remove the screws that secure the palm-rest assembly to the base cover from its connector on the system board
    • Open the latch and disconnect the optical-drive cable from its connector on the system board
    • Close the display and turn the computer over.
    • Remove the screws that secure the base cover to the palm-rest assembly
    • Using your fingertips, gently pry the base cover off the palm-rest assembly
  5. Dell Inspiron 3552 Hard Drive  Replacement Part 1, removing the base part 2: Schritt 5, Bild 1 von 1
    • Release the optical-drive interposer from the tabs on the base cover.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jordon Dozier
1.663 Reputation
12 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 948
