Zum Hauptinhalt wechseln
Dell Inspiron 5758 Heatsink and Fan Replacement
Blase Martin
Blase Martin und 6 weitere Mitwirkende
Zuletzt aktualisiert am April 29, 2021
45 Minuten
Mittel
If your Dell Inspiron 5758 is overheating and throttling, it may be time to replace your fan and heatsink assembly.
Your fan and heatsink assembly transfers heat from your GPU and CPU to the environment. If the fan is not rotating or the heat-pipe is damaged, the GPU and CPU will get too hot and they will throttle their frequency to reduce temperature. The laptop’s performance will then slow down during heavy loads.
Before using this guide, verify that the ventilation on the bottom of the laptop is not obstructed or dirty. This will prevent the fan and heatsink from operating efficiently.
Electronics are sensitive to ESD. You must use ESD-safe tools and a mat. Here is a link for using an anti-static mat and wristband.
The heatsink will require new thermal paste. Here is a link detailing how to remove the old paste and how to apply the new paste.
The laptop must be unplugged and the battery removed before opening the laptop. Step 1 and 2 cover removing the battery.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 5758 Heatsink and Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 5758 Heatsink and Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 2, Bild 3 von 3
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: Schritt 3, Bild 1 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: Schritt 3, Bild 2 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement, DC Jack: Schritt 3, Bild 3 von 3
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 5, Bild 2 von 2
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 6, Bild 2 von 2
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 7, Bild 3 von 3
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 8, Bild 1 von 1
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 9, Bild 2 von 2
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 10, Bild 1 von 1
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 11, Bild 2 von 2
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 12, Bild 2 von 2
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 13, Bild 2 von 2
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 14, Bild 1 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 14, Bild 2 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 14, Bild 3 von 3
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 15, Bild 1 von 1
    • Remove the bottom base.
  16. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 16, Bild 1 von 2 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 16, Bild 2 von 2
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 17, Bild 1 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 17, Bild 2 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 17, Bild 3 von 3
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 18, Bild 1 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 18, Bild 2 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 18, Bild 3 von 3
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
  19. Dell Inspiron 5758 Heatsink and Fan Replacement, Heatsink and Fan: Schritt 19, Bild 1 von 1
    • After removing the bottom base, you can access the heatsink and fan, which is attached to the motherboard.
  20. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 20, Bild 1 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 20, Bild 2 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 20, Bild 3 von 3
    • Unplug the cable that connects the heatsink and fan to the motherboard.
  21. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 21, Bild 1 von 2 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 21, Bild 2 von 2
    • Loosen the three 5mm screws that connect the heatsink and fan to the motherboard.
    • The screws stay attached to the heatsink and fan. You cannot pull them out, only loosen them.
  22. Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 22, Bild 1 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 22, Bild 2 von 3 Dell Inspiron 5758 Heatsink and Fan Replacement: Schritt 22, Bild 3 von 3
    • Remove the heatsink and fan from the motherboard. You can now clean or replace it as you see fit.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Blase Martin
407 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 11
Insgesamt: 640
