Zum Hauptinhalt wechseln
Dell Inspiron 9300 Processor Replacement
Steven Faulkner
Steven Faulkner und eine weitere beteiligte Person
Zuletzt aktualisiert am December 12, 2016
Keine Schätzung
Mittel
Bessere Einleitung
This guide will demonstrate how to remove and replace you CPU.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron 9300 Processor Replacement, Prerequisite Only: Schritt 1, Bild 1 von 2 Dell Inspiron 9300 Processor Replacement, Prerequisite Only: Schritt 1, Bild 2 von 2
    • Remove the battery prior to working on any internal components.
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
    • Remove the battery before working on internal components to ensure a safe working environment.
  2. Dell Inspiron 9300 Processor Replacement: Schritt 2, Bild 1 von 1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  3. Dell Inspiron 9300 Processor Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 9300 Processor Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 9300 Processor Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
  4. Dell Inspiron 9300 Processor Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 9300 Processor Replacement: Schritt 4, Bild 2 von 2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  5. Dell Inspiron 9300 Processor Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 9300 Processor Replacement: Schritt 5, Bild 2 von 2
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
  6. Dell Inspiron 9300 Processor Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 9300 Processor Replacement: Schritt 6, Bild 2 von 2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
  7. Dell Inspiron 9300 Processor Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 9300 Processor Replacement: Schritt 7, Bild 2 von 2
    • Pull up and away on the track pad to expose the internal components below.
  8. Dell Inspiron 9300 Processor Replacement, Processor: Schritt 8, Bild 1 von 1
    • Loosen the four silver Phillips screws in a criss-cross pattern retaining the heatsink to the cpu.
  9. Dell Inspiron 9300 Processor Replacement: Schritt 9, Bild 1 von 1
    • Gently lift up on the heatsink to reveal the CPU below.
  10. Dell Inspiron 9300 Processor Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 9300 Processor Replacement: Schritt 10, Bild 2 von 2
    • Gently loosen but do not remove the flathead screw.
    • Lift the CPU away from the motherboard, taking care to not damage the gold pins.
    • You will have to remove and replace the Wie trage ich Wärmeleitpaste am besten auf on the CPU base.
Abschluss
USF Tampa, Team 16-6, Eyestone Fall 2016 Mitglied von USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 17
Insgesamt: 1,031
