Zum Hauptinhalt wechseln
Dell Inspiron M5110 Keyboard Replacement
Cody Flynn
Cody Flynn und 3 weitere Mitwirkende
Zuletzt aktualisiert am December 21, 2016
10 Minuten
Mittel
This guide will walk the reader through the steps necessary to remove the keyboard on a Dell Inspiron M5110. This is necessary when when the keyboard stops functioning to its full ability, as well as when the reader desires to replace the keyboard.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Dell Inspiron M5110 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cody Flynn
331 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 4-3, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-3, Catania Fall 2016
UMASSD-CATANIA-F16S4G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 293
