Dell Inspiron M531R-5535 Computer Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace the battery in your Dell Inspiron M531R-5535 laptop.
A functional battery provides power to your laptop. Eventually, laptop batteries will rapidly drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual, consider calibrating your battery to determine an accurate charging capacity. If you continue to notice significant drops in battery percentage, you should replace your battery.
A punctured battery can cause a dangerous fire. If your battery is swollen, take appropriate precautions.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
