Zum Hauptinhalt wechseln
Dell Latitude E6410 CMOS Battery Replacement
Aaron Thomas
Aaron Thomas und eine weitere beteiligte Person
Zuletzt aktualisiert am 3. Jun 2021
10 Minuten
Mittel
Anleitung eines Community-Mitglieds
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. Dell Latitude E6410 CMOS Battery Replacement, Remove all external components: Schritt 1, Bild 1 von 1
    • Make sure you have removed all external components from your device (ie. USBs, ethernets, power cords, audio devices, SD cards, etc.)
  2. Dell Latitude E6410 CMOS Battery Replacement, Remove battery: Schritt 2, Bild 1 von 3 Dell Latitude E6410 CMOS Battery Replacement, Remove battery: Schritt 2, Bild 2 von 3 Dell Latitude E6410 CMOS Battery Replacement, Remove battery: Schritt 2, Bild 3 von 3
    • To remove the battery, slide the latches inward, and remove the battery from the system.
  3. Dell Latitude E6410 CMOS Battery Replacement, Remove the access panel: Schritt 3, Bild 1 von 3 Dell Latitude E6410 CMOS Battery Replacement, Remove the access panel: Schritt 3, Bild 2 von 3 Dell Latitude E6410 CMOS Battery Replacement, Remove the access panel: Schritt 3, Bild 3 von 3
    • To remove the access panel, use your screwdriver to remove the single screw in the center of the base. Then, slide the access panel toward the front of the system and lift it from the system.
  4. Dell Latitude E6410 CMOS Battery Replacement, Disconnect the coin-cell battery cable from the system board: Schritt 4, Bild 1 von 3 Dell Latitude E6410 CMOS Battery Replacement, Disconnect the coin-cell battery cable from the system board: Schritt 4, Bild 2 von 3 Dell Latitude E6410 CMOS Battery Replacement, Disconnect the coin-cell battery cable from the system board: Schritt 4, Bild 3 von 3
    • After removing the access panel, locate the coin cell battery. Then disconnect the battery cable from the system board and lift the coin-cell battery out of its socket to remove.
  5. Dell Latitude E6410 CMOS Battery Replacement, Replace battery.: Schritt 5, Bild 1 von 3 Dell Latitude E6410 CMOS Battery Replacement, Replace battery.: Schritt 5, Bild 2 von 3 Dell Latitude E6410 CMOS Battery Replacement, Replace battery.: Schritt 5, Bild 3 von 3
    • With your replacement battery, perform the previous steps in reverse order.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Rüste dich für deine nächste Reparatur
Alle in den Warenkorb legen
Aaron Thomas
1.251 Reputation
10 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.991 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 38
Insgesamt: 2,079
