Dell Studio 1737 Speaker Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will demonstrate how to remove or replace the speakers in a Dell Studio 1737 laptop
Was du brauchst
Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
Unscrew the 8 Phillips head screws marked in the photo.
Use a plastic opening tool to pry the panel away from the laptop body.
Lift the panel up and away.
Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
Pry black panel away from laptop body starting at the base of the screen
Flip the panel over onto the keyboard
Detach the ribbon cable from the motherboard as shown
Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
Lift from the top of the keyboard and flip it over onto the palmrest
Remove the 8 8mm ph1 philips head screws (red)
Remove also the one 4mm ph 1 philips head screw (blue)
Remove the two 4mm ph1 screws along the black panel to which the speakers are attached
One of the screws is located under a wire channel and can be difficult to spot, look closely at the photo to make sure you get the right one
Unplug the 6 marked cables from the motherboard
Pull the antenna cables out through the motherboard, free them from their cable channels, and route them in such a way that they don't interfere with the next step
Using a plastic opening tool, pry the palmrest away from the body of the laptop all the way from one hinge to the other, disconnecting all of the internal clips along the way
Lift the palmrest up and off of the laptop
Peel speaker cables off of the bottom of the palmrest, and route the cable through it such that the speakers are free
2 weitere Personen haben diese Anleitung absolviert.
