Zum Hauptinhalt wechseln
Dell XPS 15 9560 Fans Replacement
Jada Houser
Jada Houser und 5 weitere Mitwirkende
Zuletzt aktualisiert am July 21, 2023
20 - 35 Minuten
Mittel
Action Shots
Benötigt Mehr Bilder
Studierende im Gange!
If your Dell XPS 15 9560 is consistently hot to the touch, there may be a blockage of the laptop’s fans or the fans may be inoperable.
The fans are responsible for regulating the temperature of the laptop, keeping the internals cool during normal and intensive processes. To see if there is a blockage, follow this guide to remove the laptop’s backplate and look for debris within the fans. Debris can be gently removed by using a dust blower. If there is no blockage, the fans may be inoperable and will need to be replaced with the help of this guide.
The fans are not delicate pieces of electronic equipment, as they are just plastic and a motor, but they should still be handled with care, as the plastic can still break if dropped or bent.
Ensure that the laptop is turned off and unplugged before beginning.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Dell XPS 15 9560 Fans Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Fans Replacement: Schritt 2, Bild 1 von 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Fans Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Fans Replacement: Schritt 4, Bild 1 von 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Fans Replacement, Fans: Schritt 5, Bild 1 von 1
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  6. Dell XPS 15 9560 Fans Replacement: Schritt 6, Bild 1 von 1
    • Unplug the fan cable.
  7. Dell XPS 15 9560 Fans Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the left-side fan.
  8. Dell XPS 15 9560 Fans Replacement: Schritt 8, Bild 1 von 1
  9. Dell XPS 15 9560 Fans Replacement: Schritt 9, Bild 1 von 1
    • Remove the right-side fan.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jada Houser
839 Reputation
7 Anleitungen geschrieben
Clemson, Team 4-5, Hunter Fall 2021 Mitglied von Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 38
Insgesamt: 2,235
