Zum Hauptinhalt wechseln
Dell XPS 15 9570 Wireless Card Replacement
Margaret Combs
Margaret Combs und 5 weitere Mitwirkende
Zuletzt aktualisiert am January 5, 2024
15 - 30 Minuten
Leicht
Assuming you aren't using an Ethernet cable or don't have an Ethernet adapter, this guide demonstrates how you can easily install your new wireless card adapter for your Dell XPS 15 9570. The reason you need a wireless adapter is to allow your computer to have access to the internet. The guide provides clear instructions on how to disassemble the computer and provides a correct way to install your wireless card adapter. Something to keep in mind during this process is to be careful when unscrewing the back plate, as the back plate could break. Also, make sure not to lose any of the screws, or else the back plate won't go on correctly. When you get to the back of the computer, make sure not to mess with any wiring, and only focus on the wireless adapter.
Was du brauchst
Werkzeuge
  1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Wireless Card Replacement: Schritt 2, Bild 1 von 3 Dell XPS 15 9570 Wireless Card Replacement: Schritt 2, Bild 2 von 3 Dell XPS 15 9570 Wireless Card Replacement: Schritt 2, Bild 3 von 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Wireless Card Replacement: Schritt 3, Bild 1 von 2 Dell XPS 15 9570 Wireless Card Replacement: Schritt 3, Bild 2 von 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Wireless Card Replacement: Schritt 4, Bild 1 von 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: Schritt 5, Bild 1 von 2 Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: Schritt 5, Bild 2 von 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  6. Dell XPS 15 9570 Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Lift the wireless card bracket off of the wireless card.
  7. Dell XPS 15 9570 Wireless Card Replacement: Schritt 7, Bild 1 von 2 Dell XPS 15 9570 Wireless Card Replacement: Schritt 7, Bild 2 von 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  8. Dell XPS 15 9570 Wireless Card Replacement: Schritt 8, Bild 1 von 1
    • Carefully remove the wireless card.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
University of Alabama, Team 2-4, Bedsole Fall 2021 Mitglied von University of Alabama, Team 2-4, Bedsole Fall 2021
UA-BEDSOLE-F21S2G4
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 38
Insgesamt: 2,703
