Disassembling HP Envy 17-3070NR Motherboard Assembly
Was du brauchst
Remove the two 4.5mm Phillips screws from the system board
Disconnect three cables by lifting a white clamp with a Flathead screwdriver and pulling on the blue tab.
Disconnect three cables by pulling upward on black or blue tabs connected to them.
Disconnect cable by using a Flathead screwdriver to gently pry it off the black connector towards you.
