Disassembling Motorola i90c Keypad
Einleitung
Zu Schritt 1 der AnleitungToday we are going to take you to a step by step guide on how to install a new keypad.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Slide the notch downward while pulling the back cover off to remove it.
Use your fingers to push the battery upward from the bottom.
Lift upwards to remove the battery.
Unscrew the antenna in a counter-clockwise fashion.
Remove the aluminum cover.
Unscrew the 3 screws shown.
Lift up the right part of the Nextel logo and unscrew the screw underneath.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, carefully pull off the connector shown.
