Zum Hauptinhalt wechseln
Fujifilm FinePix T500 Lens Gears Replacement
Was du brauchst
  1. Fujifilm FinePix T500 Lens Gears Replacement, LCD Screen: Schritt 1, Bild 1 von 3 Fujifilm FinePix T500 Lens Gears Replacement, LCD Screen: Schritt 1, Bild 2 von 3 Fujifilm FinePix T500 Lens Gears Replacement, LCD Screen: Schritt 1, Bild 3 von 3
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 2, Bild 1 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 2, Bild 2 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 2, Bild 3 von 3
    • Open the battery compartment and remove the battery.
    • Carefully pry the front half of the casing away from the camera.
    • Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
  3. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 3, Bild 1 von 2 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 3, Bild 2 von 2
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 4, Bild 1 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 4, Bild 2 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 4, Bild 3 von 3
    • Lift the LCD screen out of the camera.
    • Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
  5. Fujifilm FinePix T500 Lens Gears Replacement, Lens: Schritt 5, Bild 1 von 1
    • Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
  6. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 6, Bild 1 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 6, Bild 2 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 6, Bild 3 von 3
    • Pry off the center casing of the camera. Separate the top and side sections individually before fully removing the casing.
  7. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 7, Bild 1 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 7, Bild 2 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 7, Bild 3 von 3
    • Unscrew the two 3.5 mm Phillips head screws in the metal plate.
  8. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 8, Bild 1 von 2 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 8, Bild 2 von 2
    • Pry the metal plate out using the spudger.
  9. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 9, Bild 1 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 9, Bild 2 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 9, Bild 3 von 3
    • Peel back the strip of black tape to reveal a red and black wire.
    • Detach the orange ribbon by gently pulling on it.
    • Detach the golden ribbon by gently lifting it with the spudger.
  10. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 10, Bild 1 von 2 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 10, Bild 2 von 2
    • The lens should now be free to simply be pushed out of its socket.
    • The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
  11. Fujifilm FinePix T500 Lens Gears Replacement, Lens Gears: Schritt 11, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove four 3.5 mm screws from the corners of the internal plate.
  12. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 12, Bild 1 von 1
    • Slide the rectangular plastic frame to the side. You'll find a spring attaches the frame to the rest of the lens casing.
    • Disconnect the plastic frame from the spring.
  13. Fujifilm FinePix T500 Lens Gears Replacement: Schritt 13, Bild 1 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 13, Bild 2 von 3 Fujifilm FinePix T500 Lens Gears Replacement: Schritt 13, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • The white and the black gears of the lens unit are responsible for the lens movement.
    • Using tweezers, adjust and replace these gears as needed. The white gear should be integrated with the rest of the unit. The black gear should occupy the entirety of its cavity.
Abschluss
Brian Lasher
325 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 19-3, Blackwell Winter 2015 Mitglied von USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Mitglieder
10 Anleitungen geschrieben
1 Kommentar zur Anleitung
where can i get these gear’s? my camera is not opening its shutter, kindly let me know.
prabhu mandhar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 875
