Zum Hauptinhalt wechseln
GermGuardian AC4825E UV-C Bulb Replacement
Tim Lourenco
Tim Lourenco und eine weitere beteiligte Person
Zuletzt aktualisiert am May 12, 2022
3 - 4 Minuten
Leicht
The UV-C bulb is a vital tool for the GermGuardian AC4825E. The light eliminates bacteria, spores, and other microorganisms in the air to assist with air purification. When this bulb goes out, the UV bulb change indicator near the control panel on top of the purifier will flash blue. When this happens, it's time to replace the UV-C bulb. This guide will demonstrate the removal process for the UV-C bulb.
Was du brauchst
Werkzeuge
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. GermGuardian AC4825E UV-C Bulb Replacement, HEPA Filter Unit: Schritt 1, Bild 1 von 1
    • Check if the purifier's power cord is plugged into an electrical outlet.
    • If it is plugged in, unplug the power cord.
  2. GermGuardian AC4825E UV-C Bulb Replacement: Schritt 2, Bild 1 von 2 GermGuardian AC4825E UV-C Bulb Replacement: Schritt 2, Bild 2 von 2
    • Grab the rear cover of the purifier with one finger on the Lock and Release button.
    • Press the button down, and pull the rear cover away from the purifier.
  3. GermGuardian AC4825E UV-C Bulb Replacement: Schritt 3, Bild 1 von 3 GermGuardian AC4825E UV-C Bulb Replacement: Schritt 3, Bild 2 von 3 GermGuardian AC4825E UV-C Bulb Replacement: Schritt 3, Bild 3 von 3
    • Use your hands to pull the HEPA filter out of the purifier.
    • After reassembly, push & hold the UV control button for 5 seconds to reset the filter change indicator.
  4. GermGuardian AC4825E UV-C Bulb Replacement, UV-C Bulb: Schritt 4, Bild 1 von 1
    • Remove the two screws from the metal UV-C shield by turning the screws counter-clockwise using a Phillips #00 screwdriver.
    • Grab and pull the UV-C shield away from the purifier to remove it.
  5. GermGuardian AC4825E UV-C Bulb Replacement: Schritt 5, Bild 1 von 3 GermGuardian AC4825E UV-C Bulb Replacement: Schritt 5, Bild 2 von 3 GermGuardian AC4825E UV-C Bulb Replacement: Schritt 5, Bild 3 von 3
    • Using a tissue or a clean cloth, reach into the exposed space and grab the UV-C bulb.
    • Pull the UV-C bulb out of the exposed space to remove the bulb from its socket.
    • After reassembly, press and hold the UV control button for 5 seconds to reset the UV bulb change indicator.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Tim Lourenco
329 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-1, Mellen Spring 2022 Mitglied von UMass Dartmouth, Team 2-1, Mellen Spring 2022
UMASSD-MELLEN-S22S2G1
4 Mitglieder
Ein Kommentar
you end after you pull the bulb out. do you put another bulb in (of course) is there a right/wrong way (which side up or down) then do you plug it back in prior to holding the uv button 5 seconds? do you turn it on prior to holding the uv button 5 seconds? Please explain in detail what I should do.
william estes - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 42
Insgesamt: 2,420
