HP 15-dw0037wm Lower Case Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace the lower case on a HP 15-dw0037wm.
Was du brauchst
Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
Set the laptop down with the lower case facing up.
Lift a corner of the lower silicone foot and peel it completely off.
Repeat for the upper silicone foot.
Use a Phillips screwdriver to remove the five 8 mm screws.
Remove the two 5 mm Phillips screws.
Insert an opening pick into the gap between the lower case and chassis.
Slide the pick around the entire perimeter of the device until the lower case fully releases.
Remove the lower case.
