HP 15-g071nr Motherboard Replacement
Einleitung
Zu Schritt 1 der AnleitungA motherboard can fail for a variety of reasons but this guide assumes that you have diagnosed a system failure and have acquired a new motherboard to use as a replacement. Understanding how a motherboard works is different from knowing how to replace one and only a limited knowledge of computer components is required to complete this process. Follow this guide if you need to replace the motherboard of your HP 15-g071nr.
Was du brauchst
Press the tabs at the corners of the laptop at the same time to release the battery.
Using your Phillips #0 screwdriver, remove all of the screws on the back case.
Carefully move the iFixit opening tool along the seam of wrist rest until you can remove it.
Remove the wrist rest once it comes loose from the body.
Remove the two screws with the Phillips #0.
Gently pull the hard drive out of its SATA connection to the motherboard.
Attach the loose data cable to the new drive.
Use one of the plastic opening tools or spudger to lift the keyboard from its housing.
Slowly lift the keyboard at angle toward the left.
Just above the blue plastic connection to the motherboard is a clamp . Use your finger to lift this bar and release the cable.
Lift the keyboard with your hand being careful to unseat the ribbon cable with the blue tab.
Use the Phillips #0 to remove the five highlighted screws.
Lift the plate off of the back of the motherboard.
The screw holding in the CD drive has already been removed.
Slide the CD drive out.
Remove the three screws connecting the fan to the motherboard with the Phillips #0.
Remove the fans connection to the motherboard.
Carefully pull the wireless card from its interface with the motherboard.
The marked connector is the antenna's connection. Use two fingers to wiggle the connector loose from its fitting.
Remove the screen connector by pulling on the plastic tab.
Gently wiggle the connector side to side while pulling toward the battery.
Slowly lift the motherboard by pinching on the middle of its right side.
Wiggle the motherboard side to side to remove.
